Old 10-04-2009, 10:19 AM   #1
proz07
Needing a new tow rig.
proz07's Avatar
well continueing with the install i have made a turn down elbow off an extra y-pipe rather than run through the crappy stock piping. i didnt use a 180 turn as then i wouldnt have enough to finish it up today so i did a sectional bend...those btw are very time consuming and if ya had to pay for it just buy an extra bend. also the relief pipe i cut off and welded over the holes for the charge control valve only cause i can .
heres that i had other pics while building but for some reason my camera didnt save them once i pulled the sd-card 14pics
and to get this done i had the my GF help a bit and strip shorten/lengthen and rewrap the wiring for the fans and if my right fan still had the plug on it it would look close to OEM those pics didnt come out heres the final. as well as reclocking the top radiator connection to work better. the universal pipe is going to be temp till i get back in feb and then i will get some 1.5" pipe to run it better
