#11 | |
![]() I grab all the stuff I need for the battery from the local NAPA/Advanced. A quick list off the top of my head is as follows: 10' 2 gauge battery cable( for the main POS and NEG cables) 10' of 8 gauge battery cable.( for powering up the fuse block) 2-4 8 gauge ring terminals 2-4 2 gauge ring terminals 2 Battery post terminals 1 rubber grommet for the hole I am drilling thru the body for the cable I fabricate my own battery hold down once I figure out exactly where it is going. 5-10 cable "hlod down " clamps to secure the cable to the underside of the car or wherever you run it 1 main fuse( about 100A) that is installed at the battery POS in case the power wire should short to the chassis it will disconnect the battery. In theory I get theses from the car stereo store.It may be less hassle to just grab a kit, but I am probably around the 30-50 dollar range in parts depending on the quality of cable you use. Plus I have done a few of them so I have a good idea of what I will run into. Yeah Tim, The rest of the car is super fugly compared to the enginebay! I am working on it!! Last edited by BigIslandSevens; 09-24-2009 at 02:00 PM. |
