Old 09-19-2009, 07:43 AM   #1
North west corner is acceptable as well
So, I found the cause of my exhaust leak.... Appears the Pineapple Graphite one doesn't enjoy standing up to a few hours of abuse. Literally burned the graphite up and left nothing but the steel honeycomb. Im going to call Pineapple as this is the second one I've had and while the first wasn't exactely a long life item, it lasted longer than this. In fact this is the third gasket I've been through. If Pineapple doesn't replace this one, which they probably will. I'll be buying a factory one.
Also found the strange noise coming from the clutch.... the T/O bearing fell apart in my hand. I'm actually lucky I made it home. The outter "wrapping" peeled away ..... and scratched of some of the purple anodizing on my clutch cover and when I FINALLY got the trans out (I need a two poster damnit) the thing fell apart sending little stainless ball beaings everywhere.
So now I just need to get the new fuel filter mounted and plumbed, take my 12 speeds and make 6, custom mounting, PRAY the driveshaft fits, and put it all back together by Thursday @ 6 in the morn...... le sigh
Old 09-19-2009, 11:49 AM   #2
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
EJayCe996 will become famous soon enough
while my car is jacked up I also spotted why my car seemed a little .... LOUDER than usual before it blew. This damn thing ALWAYS finds some way to loosen an exhaust bolt no matter how well its secured, torqued and lockwasher where I can put them. Except this time it just so happened to completely discard the bolt somewhere out on the road. This car has probably cost me more money in exhaust bolts/nuts than any other piece on it. Luckily I use SCE copper gaskets and they've been reusable after MULTIPLE issues of exhaust blow-by.
I bet you saw it and said the same thing I did.. "Ain't that a bitch!?"
1. Walk through a row of 22", or larger, rims
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
EJayCe996 is offline   Reply With Quote
