Rep Power: 10 ![]() |
Rebuild it. If you've got good comp in the front rotor and only one low pulse in the rear, it's definately worth rebuilding rather than let it sit for 2+ years
If you don't expect the motor to last forever pull it apart, clean everything up really well and reuse most of the seals. Buy new oil control o-rings, dowel rings, fire/coolant seals and just do the bare minimum. Even if a housing is chunked a decent N/A housing should be able to ba had for a bill or two. At that point you're looking at your time. Total time to do that should be in the 30-40 hour range. So wake up saturday morning and work until Sunday night and you'll be 90% of the way there. Seems like a no brainer to me.
| Tags |
| atf, mmo, seal, side, stuck |
