Old 09-07-2009, 02:23 PM   #1
Silver86
now what?
Silver86's Avatar
Silver86 is on a distinguished road
Did anyone mention doing a COMPRESSION TEST before opening the engine up???
lol... im no noob Ted... of course if did a compression test. it was the first thing i did after i got the car home after buying it. its been a few years... so i might as well try it again, just to see if anythings changed. the last i did check it though... i do remember now... i did get 3 decent pulses on the front rotor... and only 2 on the rear... that was also 3 years ago.
1986 Rx7 coupe - arctic silver - sold
aka - 20bforme
Silver86 is offline   Reply With Quote
Old 09-07-2009, 11:52 PM   #2
Only 2 on the rear might mean just a stuck side seal.
Try soaking the rear rotor in ATF or MMO or whatever your fav is.
1 good and 2 bad / no pulses is indicative of a bad apex seal and guarantee a rebuild.
If it's a stuck side seal, there's a chance you could resurrect the engine without opening it up...
Old 09-08-2009, 03:16 AM   #3
Silver86
now what?
Silver86's Avatar
how would i go about positioning that side of the rotor down so itll soak? crank the engine by hand?
err i worder that wrong... how would you do it Ted?
aka - 20bforme
Old 09-08-2009, 01:32 PM   #4
Yeah, crank by hand.
I typically use the 19mm bolt in the center of the main pulley.
I'll pour the liquid via a hose and funnel through the leading spark plug hole(s).
Crank just enough just to get the liquid to go through.
Don't crank it too many times, and it starts to get spit out the exhaust.
Allow to soak 24 hours or overnight.
With ATF, it should fire up.
Just be warned that ATF burning causes a HUGE SMOKE CLOUD.
It'll take a few minutes to burn off.
Old 09-08-2009, 02:09 PM   #5
Silver86
now what?
Silver86's Avatar
easy enough... any particular brand of ATF? not sure if i can find MMO in my area.
aka - 20bforme
Old 09-09-2009, 07:57 PM   #6
Buy any of "cheap" ATF.
Don't buy the stuff that's specific to one model - i.e. Honda.
atf, mmo, seal, side, stuck
