#16 |
#17 |
Ray crowe ph 7034908263
Ray is a good guy
![]() RX8 2004 GT RX7 1988 TII |
#18 | |
Use lots of RTV, put hose on, tighten clamp. Leave overnight to dry. Then fill with coolant the next day. -Ted |
#19 |
What is RTV?
#20 |
Home-brew Rotary
Look for something like this in any auto-part stores:
![]() ![]() Permatex is common sealer. Different colors have different sealing properties. You might want to read the back of a package of sealer to see what its good for. Black sealant or Red sealant will be good for what you need. |
#21 |
It's back on the road! I put a temporary universal hose onto it. It works, however, Up by the firewall the hose dose have a small kink. I will order the correct part soon, and use the universal hose as an emergency back up. The brass part is okay, I did not crimp it.
Thanks to everyone for the help. Also, thank-you RETed and N.Rotary for the RTV info. |
