frustrated!
Rep Power: 17 ![]() |
Well I dropped the motor in yesterday and routed the turbo/dp/exhaust system. Also routes my EGT leads and re-wrapped my HKS mani. I am surprised how much the DEI Ceramic rattle can held up. No flaking what so ever.
Really all I have left is the UIM, LIM and fuels set up. Add some fluids and start her up. However I can not find a damn place to mount these egt gauges! it is killing me. ![]() Brian, you mentioned I should do a comp test before I let it run then one after an hour correct? I am most likely going to start her on Sunday so I will try to get it on video. I am a little nervous for the comp test but if it is low due to my parinoia about the apex seal spring installation then I will just open her up and stack again(hope not).
Same pig, new soul
#2 | |
Rep Power: 10 ![]() |
More just for curiousity. If there was anything that went wrong during the assembly - pinched side seal, apex seal, bad springs, missing a cornerseal, something horrendous like that, it'll show up in the first comp test and MAYBE you'll be able to catch it before it does real damamge but if a side seal slipped out of place, the damage was probably done with the keg was torqued. Just things to make you more paranoid. If you heard 3 clean even whooshes and the engine spun freely, you really have nothing to be worried about. It's more for curiosity. In my case, Dave and I are worried about me overoiling the engine with the OMP and a bit of premix in the gas. So my comp tests are just to make sure that the comp doesn't fall off from over oiling. Like I said Sean, if you heard some even pulses and the motor spun pretty freely by hand, stop being paranoid, clean the sand out, get some douche and go to town
