Old 07-29-2009, 05:37 PM   #1
Originally Posted by classicauto View Post
Mint (zero play) or "good" (maybe a little play)
Yep. There's several ways to check, the quick and dirty is the same as any bearing really - feel for play.
I would just get them balanced if you're not sure or haven't had it done recently. Even just age and lack of driving can make a wheel related noise. Alignment, although its a great idea to check it - won't really cause a vibration persay.......if something is totally jacked and a wheel is hopping along the road then yes alingment might cause a vibration, but generally speaking the two are NEVER related.
I see, was mostly curious if they were solid or not, solid trans mounts will shake your balls off.......in a bad way.
Is there ever a good way to shake your balls off? I don't know about you, but I like my balls where they are. I'll look more into the possibilities later this weekend.
