Old 07-25-2009, 11:14 PM   #1
If the transmission bell housing mates with the rear iron on the engine, you're good to go.
Old 07-31-2009, 03:03 PM   #2
87TurboII
87TurboII is on a distinguished road
Thanks! It was a retarded question but I like to try and double check things as best I can.
Also have another question and thought I would use my thread here vs starting a new one.
I am going through checks on the motor and the main thing I am concerned with is the oil getting where it should. My oil pressure gauge just pegs our when you turn the car on so I did what kevin says on his site and checked the oil filter and oil came out once it was loose. Oil is going to the oil pressure sensor as well.
My question now is how can I confirm the OMP system is working? I was able to use most of my omp lines except one but to my eyes it doesn't look like oil is in the new omp line. What is the best way to check this and how soon should oil being getting into the omp lines?
Thanks!
1987 Turbo II
87TurboII is offline   Reply With Quote
Old 07-31-2009, 03:23 PM   #3
Proper check for oil flow through the OMP lines is described in the FSM.
Basically, you need to pull one of the line and measure how much oil comes out over a timed period.
The specs are in the FSM.
