Old 07-06-2009, 04:04 PM   #1
I have an extra 8 gal fuel cell right now, maybe I'll keep it on tap after the troubles you're having - i was going to get rid of it, lol...
Also - I was not aware the S5 tanks were larger, hmmm learn something new every day
Extra 2 gallons and they're cheaper to boot. Best of both worlds.
Originally Posted by classicauto View Post
Fits like a charm...
Only thing is you can't swap the S4/S5 sending units/pump holder + straps (although, i didn't try to swap straps so Im not 100% on whether S4 works with S5). The S4 is shorter then the S5 as thats where it gains most of the extra volume.
So keep the senders and tanks and straps with the same series and you're golden.
Thanks Joe! So here's a question for you. The top mount dealy..... is that interchangeable? Meaning can I transfer my pump and sending unit and the top mounting piece to the S5 tank or do I need to source one of those as well? I know the fuel lines are slightly different (not a concern as mine are all -6AN stainless tube) and the wiring is different (again, not a concern becuase all of mine is redone anyway) and I believe the sender is different ohm'age (don't car, programmable gauge, although if it's deeper I'm screwed..... damn ) but is the gasket pattern the same?
Come to think of it, my buddy had an S5 before he bought the S4 TII so maybe I'll just grab that from him and see.
As for the straps, that would be a bummer if they were slightly longer. I guess I'll find out through the parts fiche though. Thanks a bunch Joe
Old 07-06-2009, 04:13 PM   #2
classicauto
crash auto?fix auto
classicauto's Avatar
The mounting pattern for the "cover" piece is the same, the main difference is the length of the assembly. But bolt pattern wise they're the same where they attach to the tank.
Yeah like I said on the straps I'm not 100% sure....the last time I did that swap was a few years back on a resto for a customer and I don't recall which series straps I used. I bet though, that even if the S4 ones are shorter, you can probably tighten them down anyways given the length of the bolts.......but either way its nothing outside of your capability
Old 07-06-2009, 04:27 PM   #3
Again, your logic is undeniable (I need some flippin sleep). I guess I'll be trading mine for his when the time comes. It might even save me from buying another sender if his is in good working order. Cool, thanks Joe.
Now lets see how long I can put off buying a tank. I've been using his diff since DGRR He's going to need it back at some point.
