| Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's |
New style hard nylon motor mounts
This design features no metal to metal contact.
More pictures of motor mounts
Shows the finish product. Can be cut to the length needed as used with the garfinkle oil pan brace.
hi ,
how much is it costs? how i install them? do you have any webpage to take a look? thank! |
The cost is $200 shipped in the USA .I will need to get your old set in exchange .They install as the stock ones after you drill the frame hole out to 1/2 inch .I use a 1/2 inch grade 8 allen fine threaded bolt and self locking nut with it for more strengh .It is easy to drill the holes from the bottom .I do not have a webpage .The mounts can be made 3/16 inch shorter if you are using my oil pan brace,then the motor will sit at the stock height. Thanks David
looks nice man
500+ HP thanks to: ![]() Fast reacting IAT sensor thread! Mechanical Pre-turbo Water Injection Thread Dual Stock fuel pumps Thread T2 differential swap! |
To those who have bought motor mounts and not sent back the old stock cores please do so to complete the deal ,thanks .
I don't want to be rude or out of line but are these less likely to melt or crack and crumble from the heat like the red versions I bought years back (in a group buy from another vendor)?
I was told they will resist the heat when I bought the materal. Maybe they lied,as with any of my things if it fails in a unreasonable time get your money back when you return the part.
#9 |
Rep Power: 10 ![]() ![]() |
goracer, glad you found the link
![]() Garfinkle is a stand up guy and all his parts are well thought of. I don't think you'll have any issues with his products... also just as he stated, he will give your money back if it fails.
#10 |
Very nice. Are these for 2nd gen? or 3rd gen? (sorry for the stupid question, probably obvious to everyone else)
#11 |
third gen
#12 |
David, how is ur nylon mount compare to polyurethane mount and the factory rubber mount? is it harder or softer?
#13 |
Hard compared to factory .
| Tags |
| garfinkles motor works, motor mounts |
