Rotary Tech - General Rotary Engine related tech section.. Tech section for general Rotary Engine... This includes, building 12As, 13Bs, 20Bs, Renesis, etc... |
#1 | |
Rep Power: 10 ![]() ![]() |
Rotary Engine Failure due to Side Rotor/Side Rotor Housing Clearance..
I'm also curious how you are going to save money.. Because I thought you still have to buy a short block ![]()
DGRR 2013 - Year of 13B www.DealsGapRotaryRally.com http://www.facebook.com/Herblenny Last edited by Herblenny; 07-02-2009 at 03:06 AM. |
Always Under Construction
This thread is based on conversation that took placeHERE about if clearancing the rotor is necessary or not on street driven engine. Posts are moved here by request
Who clearanced the rotors for you? Also, what is the purpose? Running high levels of boost?
BLACKADDE™ | ADGT RX7 | Last edited by Herblenny; 07-02-2009 at 03:08 AM. |
I'm confused also.. maybe because its late at night but what does it entail when you say "race clearanced"??
#4 | ||
one broke moderator
Cool, I guess than you need what Glen did..
See there we go . Phill now you have the info you wanted and i dont have to give up out propreitary numbers to explain myself, basic idea is the same yet our numbers are different
I have to say phill that I disagree with your builder. I cleanrece all of the rotors we use in engines that we build.
There is no risk in having it, only a risk in not having it if you are running more power than stock. This is my professional opinion. Basically you have a rotor that has clearence for operating in what the stock form was engineered for. By increasing combustion pressure you are going to move the rotors back and for more often and with more force risking the rotor touching the side plates.... |
Glen,
So, why is it that you now want to discuss this when earlier today you didn't?? When I first asked, I wasn't asking you to provide with exact number that you are shaving.. i was mearly asking what you meant by increasing the clearance of the rotor as I wasn't sure what you meant by that.. Regarding to your professional disagreement with my builder..., I'm a firm believe of 30+ years of experience and his ability to do many things at the same time hiding from general population. For years, he did not want to build anyone's engine and asked me not to give out his number. Its just recently he decided to build engines as his children are older and now wanting to get back to rotary. He also pointed out to me things that I never noticed before during my research and his explaination made sense vs. no explanation or BS reasons people like to feed. Regarding his detail reasoning why he doesn't think its necessary for street driven car is I guess same reason or similar reason as why you would shave it in the first place. Also, if you truly believe its necessary then why wouldn't mazda do it in the first place..
#9 | |
Mazda does do it....If you buy rotors brand new from mazda they have a clearence. It is better to increase it ...I stated that before. You were asking me to give you details on what we do this is not for the public this is some of the things that gives us our edge. If you read what I said phill....you would have seen clearly that I stated we increase the clearence that was already there from mazda do to increasing horse power..... |
#10 |
Also. let me be clear Mazda clearenced these for a certain output of a 1.3l engine some from 100 to 255 and yes the rotor "clearence" increase as the output does from the factory, Phill......
What people need to remeber we are taking this 13b were it was never ment to go.... 1.3l puting out 500hp ...250hp per rotor (no its not that exact).... So I believe if you are building an engine for higher hourse power you need to compesate for the increase in power. Phill, I dont know who your builder is but I have to say I know hacks that have been doing this for 40years and I know poeple that are ungodly good that have been doing it for a short amount of time so 30years does not mean much to me. When some one says not to do it in street cars are they saying stock .... This is why i disagree with this guy becuase from what you said he said it is not good for the street and you have to be careful doing.....This is just not true, you can go to far with the clearencing but if you have it done by someone that knows what they are doing it is not an issue at all to have it and can not be bad no side eefects like in porting something to big and a side seal could drop etc. Look I believe that clearencing is something that everyone should do increasing horse power I have seen the effects of not having it in high horse power applications some survie some dont and I am in the business of all staying alive my company and reputation demand it Ok ....so Phil so far nothing I have said give my process away from they way you cam across you wanted me to give specific details to what we do I am not going to do that. I am in business to be the best and I am going to keep it in our bag of tricks that make us one of the top builders. |
#11 | |
It wasn't until I posted what Racing beat consider clearance and their recommendation is when you became more involved in explanation..
#12 |
Clearancing the rotors is a definate when you are running high HP applications. Its not just needed for the sides, its also needed on the combustion faces of the rotor. When there is e shaft flex you want the rotors to have enough clearance so that the rotating assembly doesn't have any contact with the stationary housings. When there is contact, it gauls up seal grooves and also causes bearing failure. People do it differently and there is more than 1 way to do it.
#13 | |
WOW Glen, Did you even read my initial question??
Here it goes, read it again.. Quote:
Regarding your statement about my builders, I could say the same about pretty much every builder out there.. Including yourself.
#14 |
And finally, Let me point it out to you again..
Glen, if you read what I stated before, I said it is NOT necessary. You do know what that means right?? It means NOT ABSOLUTELY ESSENTIAL! Which means, its not required, ie, many many engines that have stock internals that have lasted thousands of miles without having this clearancing done.
#15 |
Hey Phil.
If you look at his picture of the rotors, you can see that the sides of the rotors have been ground. Grinding is the most true surface you can get. It looks like he did a good job on the machine work. We do not know how much material was removed. The rotor housings are 80mm wide and the rotors have a slightly smaller width. If there is more torqe on the tension bolts, it can cause the tolerance between the rotors and the irons to be tighter. If there is too much material taken off the rotors during this clearancing process, there is going to be a problem with too much area of the side seals seeing combustion. Side seals, when they fail, usually anything it touches gets destroyed. I know that Louis does a very good job on his grinding work. To be honest he is the best I have ever seen. I have gotten brand new irons from mazda that didn't look as nice as his lapped irons. I don't know much about his engine building skills, but if he does that kind of lapping work, I would trust him to build my engines. I am a do it all myself kind of guy too ![]() I have never clearanced rotors for any of my personal engines. I have made 435 RWHP on one and 440 RWHP on the other. The 435 car spun a bearing after 50K miles which is due to lack of oilmaintenance. The other is in my 1st gen which is still kickin it. I guess the true test will be done when the T72 goes on with the custom upper manifold.... Last edited by Bryan@BNR; 06-29-2009 at 11:53 PM. |
Bookmarks |
