crash auto?fix auto
Yea I saw that one of the slots was quite a bit wider..don't recall if you said it was the front or rear though. IIRC the rear was fine, but front haad one out of spec?
I guess my pic viewing micrometer needs a recalibration haha.....but yeah as long as your measurements show they're in spec, you're rockin!
#2 | |
frustrated!
Rep Power: 17 ![]() |
Ha, I actually measured them bro. Front rotor slots all measured between 2.01-2.04mm. The bad rear rotor had one side with 2.03-2.05 BUT the other side of the rotor measured 2.15-2.18. No good in my opinion. However, I can not find specs on the wear limits. ONly specs when Apex seal is installed via FSM.
Same pig, new soul
#3 | ||
Rep Power: 10 ![]() |
.15-.18 is too much slop IMHOQuote:
BTW Sean, housing went out on Thursday Lemme know when you get them and what you think.-B
#4 | |
frustrated!
S5N/A rotors really?? Isn't the compression ratio too high? Shit I can't find any s4 or s5 TII rotors for less then 400.00 a pair. BUT there are a shit load of N/A's out there in great shape for cheap. I would have to re-tune for sure since I am pushing 15psi. What are you running bro?? BTW thanks for getting the housings out.
Same pig, new soul
#5 | |
Re-tuning is going to be mandatory regardless of whether you change anything. You're going to have a much healthier engine at the end which will mean that things are tighter and she'll probably run leaner anyway. The S4 n/a's are 9.4:1. S4 TII - 8.5:1 S5 TII - 9.0:1 No worries on the housings. I feel bad that they were a day late. Please PM me when you get them though. -B
#6 | |
frustrated!
The last time I researched on using N/A rotors with 15psi, it was looked at like major SIN. I know Aaron cake is running 12 psi on his N/A turbo application with no problems yet.. Hmmm....interesting. If Lucky 7 can't find me a S4 TII rotor OR give me a good price on a pair he has I MIGHT just go this route.
Same pig, new soul
#7 | |
Rep Power: 20 ![]() |
