| CJ-Motorsports Specialty fuel system products |
Original CJM Fuel System, confirmed fitment with GZ LIM
Hi guys, I am Charles, the significant other half of CJM.
We just test fit it all up, and the current system DOES fit with the GZ LIM.. so no worries for those who already own the system. Minor changes are still coming for the 2.0 production batch since the secondary was already redesigned for additional firewall clearance, and a minor change will be made to the primary so its less tight of a fit with the GZ LIM... but once again, no worries, the existing kit already fits. |
All you have to do is rotate the injectors.
Always Under Construction
Please be sure to let us know when v2.0 is available.
I dont know why that works on yours and it didnt on mine. I have precision 1680cc injectors with their clips, yours are different. What are they?
These are 1600's as well. But the only clips that I have are the ones that we cut off a old DSM harness. I will have to source some different types of clips, and see what the differences are.
Just to add, the clip part is not the red/brown plastic piece. It is actually black and looked like all others I have seen. I was thinking that these were actually larger than the standard RC injector clip.
You also have to put the clip on before you bolt down the rail. |
will you be able to modify the secondary rail to use four injectors instead of two to work with the gz lim?
Hey, since you guys aren't going to answer phones, PM's, or e-mail, how about you post your findings and where you can get these injector clips---everything I've come across doesn't fit and I'd rather not use an old DSM clip hacked off a junkyard harness.
Thanks. |
#9 |
Sorry we do not check the forums often anymore.
Email at sales@cj-motorsports.com is the way to get ahold of us and no email will go unanswered. |
#10 |
BTW we have no other findings on it. We have not tested other injector clips since we do not have any, the DSM harness just so happened to be laying around so thats where we got the clips from. I would recommend the DSM forums for their stock injector clips, probably much easier than digging through junk yards. But I would bet there has to be other clips that fit also. The new primary rail is different so that this is no longer a problem.
