Old 05-19-2009, 12:56 PM   #1
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Yes, Those are factory original connectors. Although they sure look like FD3S?? It is a better set up because you are grounding battery, chassis and motor with one wire. Better than just the two on the motor that are stock.
Just make sure both they and mount points are clean.
Use some electrical paste to help to keep corrosion from forming. I've been using Wurth CU 800 for years.
To test for cranking voltage just hook you meter up to the battery and watch it while you turn the key.
Old 05-19-2009, 03:08 PM   #2
Rotary#10
Rotorhead
Rotary#10's Avatar
hey checking the ign switch again and there is no continuity on Start position between B - IG1 also on ST-L-E-K1-K2.
On all the other terminals and position laid out in the FSM they have continuity but the start position and the terminals. Would that explain why it wouldn't crank?
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
