Old 05-18-2009, 02:32 PM   #1
FCpilot
FCpilot is on a distinguished road
Decluttering my engine bay?
I've got my engine out for a rebuild, and am wondering what people have done to tidy the compartment up and free up some space. Everything that came with the car in in there, with the exception of the air pump.
Thanks for your input.
FCpilot is offline   Reply With Quote
Old 05-18-2009, 02:51 PM   #2
relocate battery to the storage bins
replace airbox with K&N Cone filter
replace clutch fan with electric unit
remove A/C
Remove P/S (not recommended if you plan to drift)
remove ACV
Remove OMP (only on S4, if it's broken, S5 cars need a ECU chip to remove it)
Remove charcoal Canister
purchase a radiator cooling panel (corksport)
replace the exhaust manifold with a Racing Beat header (performance gain and looks a LOT better)
These things are all unnecesary, but that's a good list. There are complications that arise from some of these "mods" that you need to consider before actually doing them.
Old 05-18-2009, 03:51 PM   #3
Fidelity101
Reliable Source
Fidelity101's Avatar
remove A/C
remove ACV
woot! I've done all that except the cooling panel and you forgot to add remove the air pump.
and if you wanna get even more nuts go with an electric water pump
My Rx-7 Vids
Old 05-18-2009, 03:57 PM   #4
Old 05-18-2009, 04:16 PM   #5
Fidelity101
Reliable Source
do'h!
My Rx-7 Vids
Old 05-18-2009, 04:42 PM   #6
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Convert to mid-engine.
But yeah, basically everything that's been said already. Also having a squeaky-clean engine bay really improves the look.
Old 05-18-2009, 05:53 PM   #7
Fidelity101
Reliable Source
now that would be sweet and akward.
my engine bay is pretty tidy minus all the wires going everywhere (I cant wait till megasquirt!)
My Rx-7 Vids
Old 05-18-2009, 07:30 PM   #8
FCpilot
Thanks for the list. Has there been any effort to make the wire harness into something less awful? So far I've decided to simply re-wrap the thing.
Old 05-20-2009, 10:56 PM   #9
/\ dont do it!'
Maybe I just suck at wrapping harnesses, but it gave me hell to do mine! A lot of the plugs either had too much wire, or didnt reach quite right, so I had to redo it twice!
I would reccomend simply getting some "non-chlorinated" brake cleaner (wont harm the plastic connectors) getting the harness dissconected, and spraying it down/wiping it off.
This will make it look a million times better and save a million headaches...
Old 05-21-2009, 10:36 AM   #10
FCpilot
/\ dont do it!'
That's useful information. Thanks for the heads up.
Old 05-21-2009, 05:40 PM   #11
Fidelity101
Reliable Source
you can just go to a standalone ECU w/ its own neater harness.
My Rx-7 Vids
Old 05-21-2009, 06:38 PM   #12
Here's some other things you can do if you're adventurous:
  • Relocating the coils to inside the cabin and using bulk head connectors to get the spark to the spark plugs.
  • Remote mounting the AC/PS Pumps (hehehehe, I don't think anyone has figured out how to do that quite yet... but I have something in store)
  • Re-do the hard brake lines to run inconspicuously instead of all over the place
  • Custom intake manifold for cleaner install/look
  • Hide heater core lines to be out of sight/out of view from the upper portion of the engine.
  • Bulk head/cannon plug the engine harness and re-wire it to mount directly over the transmission.
  • Stainless steel parallel fuel lines
  • AN fittings just about everything you can
  • Relocate clutch lines to be inside the firewall
  • Construct heat shields and proper ducting to the air filter
  • Replace stock recirculating tank
  • All aluminum radiator
That's about all I can think of right now.
Old 05-21-2009, 07:02 PM   #13
no airpump? Do you have the yohoo belt or pullies to make sure the water pump is getting proper belt contact at high RPMS? why are you rebuilding btw?
ditch the PS, the way the road feels without PS is worth it. parking isn't fun with wider wheels but you get over it. Max did a good job with the list, you can't really take anything else out besides the AC lines and coils.
SOmeone said electric water pump, it cleans up a lot of space for sure:
just impretend all the cool stuff isn't there....
THere is so much going on in that picture it hurts....:drool:
Old 05-22-2009, 04:47 PM   #14
FCpilot
I'm rebuilding an engine with overheating problems (bad seals). I didn't put the two belt pulley on, through my car is a daily driver that doesn't see a lot of high revving. I do intend on replacing it with a two belt pulley at this time.
Nice clean looking bay.
1986 RX7 GXL, N/A. Engine rebuild in progress.
Old 05-21-2009, 07:07 PM   #15
You can still clean up a lot of things from that bay...
As for the electric water pump... how do you even mate that to the engine without the waterpump housing?
