Old 05-15-2009, 03:51 PM   #1
Ah - I dont recall the testing procedures for the air solenoid... but if you connected it and all hell brakes lose, and disconnecting it corrects the problem then I have to believe that something mechanical is bad or going bad, not sealing, etc.
Have you done a spray test? Connect that and let it do its funky idle and hit that area w/ some starter fluid and see if it sucks it in and smooths the idle out....
Pretty sure it's not a vac leak as it idles fine only when the electrical connector is disconnected. If it were a vac leak, it would do it regardless of the solenoid being active or not.
