Old 05-15-2009, 02:41 PM   #1
On the BAC - do you have a/c (are you using it and is the belt connected?).
Also - run a test on the BAC itself. If the valve is bad it may cause that as well.
On the RTek, not sure... I've never played w/ your newer version only the one you CANT edit anything on, lol.
Nope, not running air conditioning at all... I'm going to hate life this summer. I'll figure something out though... Something that you can't see but still blows cold cold air...
As for testing the BAC, I'm curious, test both solenoids? The one with the injector style connector and the Air Solenoid that mounts below it? Honestly that's the only thing that's changed is the one solenoid that sits below the injector styled one.
