You should always get 12v to the injectors when ignition is on, ecu grounds the injectors to open them, if it's an 87/86 check the resistor pack as well it may be bad or disconnected it's around where the airbox is. Otherwise i'd say you probably have a bad fuse or your wiring harness is fucked. Also, NA or T2, what year exactly?
