Blue Blur
Im kind of scared about what my harness really looks like, last time i had to peel back the tape on the main harness from the computer it was full of old coolant (shudder......)
Clean S4 Nutswinger
Kind of a stupid question (I'm an electrical noob lol), but for the pressure sensor reground, do you basically just cut the wire, and solder the ends back together with a 3rd wire added to the joint, and ground that 3rd wire?
Like this?
Rep Power: 20 ![]() |
Yeah. I would also suggest cleaning the factory ground point as well.
rotard
i did the hks circle earth system, gold plate to negative battery with 6 wires coming off to engine, one to each of the housings and one to each of the irons
and one to the main harness ground. i have no hesitation at any point, and no more bogging from starts. this is in my 90 GTUs
pissed off?being that close to a rotary, id say youd be pist-on |
#5 | ||
Rep Power: 10 ![]() |
The housings are key for good spark so I would definately ground those, as well the ECU points, housings, waterpump housing, TPS, pressure sensor, and maybe the MAF. Everything should be common and leading to a GOOD chassis ground or to the battery. When I did mine I started with an 8 gauge grounded by the ECU that spiderwebbed out with CRIMPS (NOT solder) to hit all the key points.
