Old 04-25-2009, 02:17 AM   #1
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
Originally Posted by Gravity Fed View Post
typical with flooding cars.
Wouldnt this mean bad seals though??
Old 04-25-2009, 07:37 AM   #2
Shadow24v
Shadow24v is on a distinguished road
the oil was about the consistency of water and smelled like the varnished fuel i drained out of the tank.
i didn't do the oil trick but it seemed to have enough compression to start fairly easily. i think the 3 cranks was only because the fuel system was empty.
i ran it for about 5-6 minutes before i ventured up to 7000, i twas already the coolant temp was climbing, probably 1/4 up the gauge when i ventured into higher revs (only part throttle anyways) the "block" is easily 2+ miles around
it initially idled around 750ish but after the drive it was idling lower.
the beep was a 2-shot, "beep-beep.......beep-beep"
exhaust is a stock 2-cat (i think) system so it very well could be crap built up in the cats. it was smoking out the exhaust a little for a few minutes after i parked it.
I'll double check the M/C inside the car to see if its leaking there
Shadow24v is offline   Reply With Quote
Old 04-25-2009, 01:43 PM   #3
Not really. Too much fuel will wash out the oil film in the engine. The fuel will make its way to oil.
