Old 04-21-2009, 06:40 PM   #1
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Bad install, bad bearing to start with. Blocked oil passage. Anything is possible.
Yes oil pressure should usually give you some indication.
If turbo isn't coming apart not much more that can cause that kind of noise. Fuel delivery or ignition issues usually don't sound like a bad rod. Could be quality of sound on vid but sure sounds like metal on my computer.
Air pumps can make really nasty noises especially when they shuck a seal. Parts get stuck in the ACV and cause rough running. Partially blocked exhaust will cause lack of top end power, but you would notice higher water temps when run for any length of time.
If you can get a hold of the old tape compression tester to use it gives you much better read out for diagnostic.
Old 04-22-2009, 02:29 PM   #2
Don't think that is it. I stand behind the company that built my engine, and it has ran FLAWLESS until now.
And my Oil Pressure is spot on.
I am thinking that clunking is something else, like something banging because the engine is shaking so much. It isn't that loud in person. I might need to look into some new motor mounts. LOL.
No air pump, infact I have never had one on this car.
When I bring it home, I will look into it more. Starting with replacing the coils, and checking the injectors harness, and the injectors themselves.
The only good thing is, if it is toast I will make it better next time.
