Old 03-18-2008, 08:38 PM   #1
I8U
KONI Challenge Crew
I8U's Avatar
I8U is on a distinguished road
I haven't checked my fuel filter.. Don't even know where it is I haven't searched it.
Well, you might as well give up on the fuel filter...it's a combo piece part of the fuel pump. If the filter is bad the whole assembly must be replaced...$297 if I remember from when I was quoted about 6 months ago. Besides anybody really looking for better MPG's in this car might as well trade it in and get a Civic. I normally average 11 mpg in town and anywhere from 18-27 on the highway depending on how spirited I drive. But it's a sports car, I really don't care about shelling out money on fuel. Phil, be happy you're getting the mileage you're getting...I've talked to others that are far worse even driving all highway.
Also, when traveling the highway try keep your rpm's below 3800, it helps greatly since the secondary injectors don't open up until then. I know that's right around 70mph, but it does conserve the fuel..
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
I8U is offline   Reply With Quote
