Old 04-03-2009, 12:02 AM   #1
Black91n/a
Black91n/a is on a distinguished road
IIRC (I looked it up today at work), there's more anti-wear by about 80% (lower speeds, higher loads, so its needed more), but I don't remember the rest exactly.
Basically by running diesel oil, you're saying you know more about lubrication than the lubrication experts that set the standards, and that's just not the case. If you're worried about it, just run a good quality synthetic. Amsoil is apparently about the best you can get.
Black91n/a is offline   Reply With Quote
Old 04-03-2009, 07:21 AM   #2
Long time Shell Rotella-T user here...
Got no problems, and tear downs don't reveal any problems...
I get a little lazy at times and lengthen service intervals to 5,000 miles.
Yeah, I know...I know.
The car doesn't get run hard nowadays.
1987 Turbo II
13BT
Haltech E8
Last put down 240hp at the wheels on a DynaPack dyno
Daily driver
10 - 12psi of boost max
Premix'd with Valvoline Multi-use premix in the blue bottle
Old 04-03-2009, 06:14 PM   #3
Black91n/a
I had another look, they've typically got more anti-wear and more anti-corrosion, dispersant and detergent additives. That might sound like a good thing, but really, if you don't need it, it's better to not have an additive, since you get less actual oil in your oil.
Old 04-03-2009, 06:18 PM   #4
That doesn't take into account CJ4 which is for hi-rev/hi-load diesel engines.
