As for the thrust bearing I use vaseline to hold it in place. My advice to double check it is the front cover ( I use to have the same problem but it end up the Turbo return lines that goes to the front cover had been leaking and it drip down the oil pan) Only reason I want you to double check cause tackling the fron cover job is not fum for the first timer.
