Old 03-26-2009, 10:13 PM   #1
Post
so many wires and lines!
LIES! That's the simplified version of everything. You should see what a stock 13B-REW or RE looks like!
For the front cover do you wait until you've mounted it before putting on the front ring (I think it's an oil control ring or something--the orange one)?
If you're referring to the front e-shaft seal, than yes. I generally set the end float..... which took 4 hours today (lots of sanding that spacer down on by flat/level/true workbench with some 320gt paper, restacking everything, retorqing the hub, rechecking, and repeating but I got it to .0018" ) flip the motor so the e-shaft is vertical, stack everything for the last time, instal the oil-pump sprocket, chain, put a little hylomar in the oil passage, put the nylon ring in, the o-ring, lay down a bead, put the gasket on, lay down a bead of rtv on top of the gasket, put the front cover on, torque that down, put the oil-seal in, put a little oil on the inside of the seal, put a little oil on the front hub, install the front hub, replace the o-ring on the front hub bolt, then a smear of silicone on the bolt itself, torque that down to whatever I was using when setting the end float. That's important to note. If you torque it down more than you were doing when you were setting it, it could be out of spec. I used 105 ft/lbs. Slightly higher I know but it makes me feel all warm inside.
Originally Posted by classicauto View Post
If he's waiting for the nylon seal, its likely the o-ring that will cause 0 oil pressure if it falls out or breaks. The one coming off the oil pump feed in the front iron. should be mounted when the front cover is (finally) mounted along with the front cover gasket etc.
Yup, that was the one I was waiting for. Apparently Gibson believed that the hardware store nylon washers were good enough. When the engine arrived, I saw a nylon washer, assumed it was the right one because there was a good bit of casting left visible so I only ordered the o-ring. When I went to assemble everything the o-ring wouldn't fit. My mistake for assuming. Oh well, didn't hold me back, there was plenty else to do.
