| View Poll Results: Which makes a better daily driver setup? | |||
| 13BT stock port, 8psi, EFI |
5 | 62.50% |
| Weber 48, stock port, Carb |
3 | 37.50% |
| Voters: 8. You may not vote on this poll | |||
The quickest way to kill a rotary is to overheat it. 2nd would be to turbo it. Awesome power when things are perfect, but one glitch and you're done.
Perfect setup? Mine, only keep the Illuminas on the rear instead of the Bilsteins (a bit harsh after the first 1/2 hour or so). Set the shocks on 1 or 2 and you've got a comfy cruiser. Jack them up to 5 and you're ready to hit the track. ![]() .
