Old 03-12-2009, 11:42 PM   #1
well if you want to do the poor mans compression check, remove both leading plugs and the EGI and INJ fuses. Have someone crank the car while you listen in the engine bay. Should have 6 even "whooshes" as the compression goes past. If you have a pulse or two that sound weak then there is a serious issue.
