Old 03-11-2009, 12:11 AM   #1
IH8DSM
IH8DSM's Avatar
its getting almost 40 psi, the plugs being wet i was just saying its getting into the chamber.
Old 03-12-2009, 05:43 PM   #2
fire85gslse
fire85gslse's Avatar
Try vacuums, also try putting jumper cables on the ground terminal on the battery and the other side on the frame, then try motor? Maybe you lost a ground and the ecu is not getting proper voltage.
Check pin out on ECU to see if your getting proper voltage.
When it revs can you hold the gas and it stay running?
If not check exhaust. Maybe its plugged up tight!
Hurry up and figure it out before it gets towed off.....
Last effort - Try bolting a carb up to it and see it it will run.
Old 03-14-2009, 01:42 AM   #3
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Also check your brake booster hoses. Is there power to the distributor with ignition on? I had one come in once that had an ignition switch go bad. Uncommon when these guys were younger but they are getting a bit long in the tooth now.
Exactly what were you doing when it died? Notice anything just before it stopped?
Old 03-14-2009, 07:17 AM   #4
fire85gslse
it is the same problem that I had with my SE when I was trying to put the SE lower intake on my S4 block. There was something there creating a vacuum leak and well I had to put the S4 lower back on because I could not get it after 3-4 tries. So I still say Vacuum but it could be power. Have you checked the pin voltage at the ECU yet?
I tried to call you and charles with no luck. Even texted you!
Old 03-16-2009, 12:47 AM   #5
IH8DSM
IH8DSM's Avatar
ignition switch is good we checked that and it was running like a top no weird noises, was driving normal like 2 grand in 5th gear doing about 40-45 some where in there not revving high or anything and it just died.
we did the jumper cables no difference, when it first died id be able to start it rev to a grand then just die now it wont even do that it just cranks. We're gonna try to check the exhaust this week and i still need to find the pin out
yea we've been busy working, well charles has ive been supporting miller lite and such.
