Old 03-04-2009, 09:41 PM   #11
If you have an FC (which it seems you do) your car also has a CAS. That is unless someone has replaced it with a distributor from a 1st gen.
CAS stands for one of two things:
-Camshaft Angle Sensor
-Crankshaft Angle Sensor (although in rotaries it technically is an Eccentric Shaft Position Sensor)
You should do some research........ALOT of research!!!
