		#16 |
				Rep Power: 20 ![]()  |
			Mazda Comp mounts are amazing.  I could tell a difference right away (well... I did have a broken stock motor mount) and there is no vibration coming through unless your engine is on the fritz or in need of a rebuild... which reminds me.
	The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group  |
		#17 |
				Rep Power: 18 ![]()  |
			Don't use hockey pucks. However, I did know a guy that used the window sealant stuff on his old motor mounts to stiffen them up. Worked out quite well and doesn't feel too bad.
	Problem with Garfinkle's brace is it's FD specific... Mazdatrix also sells a strut tower bar that has a torque brace but that thing is on the front...  |
		#18 | ||
			 rotors excite me
 I could see that happening, maybe.... the rubber bumpers on the RB bar mount will apply force over an area of approximately 1.5 to 2 square inches. Even making 600ft lbs of torque, the bar connects at what, 18" from the centerline of the e-shaft? That would apply 400lbs to a bumper against the sheet metal... I guess I don't know if that would be enough to tear it out, maybe after a lot of abuse. I'm gonna guess that if you're making 600ft lbs of torque with any 13B or a 12A you will already have something else figured out to keep your motor from tearing itself out of your engine bay, but I don't know.
		#19 |
				Rep Power: 19 ![]()  |
			So what I'm hearing is Garfinkle should start making FC versions, lol....
		#20 |
				Rep Power: 22 ![]()  |
			He said something about it long ago, but it never happened.  Now he lives 40 minutes away instead of 2 minutes, and I don't know of any FC's where he lives now.
	1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5  |
		#21 |
				Rep Power: 21 ![]()  |
			hockey pucks eh?
	For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook  |
		#22 |
			 Rotorhead
			anyone up for a friendly game of hockey? mmm just reading this it makes sense to me about the top of the motor twisting, i didn't know that.. mmm learn something new everyday...
	Currently running: 90 GTUs converted to S5 TurboII. Track car. 90 N/A GTUs.. Running project car 89 N/A GTUs in Black #2 10/6/18 Blown coolant seal undergoing rebuild and restomod.  |
		#23 |
			 Reliable Source
			I dont want stock ones, and I don't want to break bank for solid mounts so within the next couple weeks I am getting mazda comp trans/motor mounts for when the motor/trans goes back in the car.
	I had a broken P side engine mount too  |
		#24 |
			i dunno, the reason I didn't get the Mazdacomp mounts was because the stock design which is prone to failing....
			After a while I will report back on my banzai mounts, to see if I can give some insight.
	Rotaries:They are NOT that complicated!  |
		#25 | |
 However, I would be more than glad if you could find some posts about the stock ones failing as I am thinking of replacing mine for peace of mind (although Kevin said they were fine as of 3 years ago on my 86 with 120k+ miles).
	1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present."  |
		#26 | |
			 crash auto?fix auto
		#27 |
			Well, one of the mounts on the thread-starters FC project car was done, and the other was better, but if you look close the rubber is always micro-cracked on all the ones I've inspected so far, including some I got with my short block.
			Maybe it's because of owning a car with a REALLY sloppy drivetrain before( 1996 Mercedes C220) that I want to have my drivetrain "planted" and not move at all. Also big part is that I am planning on doing some drifting, and drivetrain slop really sucks for that.
		#28 |
			[QUOTE=Max777;75603]Well, one of the mounts on the thread-starters FC project car was done, and the other was better, but if you look close the rubber is always micro-cracked on all the ones I've inspected so far, including some I got with my short block.QUOTE]
			I wouldnt say there prone to failing. max being micro cracked would fall under the terms ageing or weathering. im sure with 20 years of abuse most mounts would have micro cracks. And as far as the design being the same as mazdas oem. if its good enough for mazda then its good enough for me.
	1988 Fc Vert. Super Stock 1990 Fc Hard top: Brideported 13b, weber carb, 350z wheels w/nitrogen, or 16in BBS meshies, Msd, Racaro Racing Seats, Custom Gauge cluster, custom Intake, Relocated Battery, 3inch header back borla exhaust system, Alpine stereo system, Wire tucked, S4 shift boot&knob, custom Strut bar, And soon to come a Full black w/ gold pearl paint job, powder coated break calipers, all black interior, bride headliner/door panels.
