#1 | |
Out of Nickels and Dimes
1: Read the FSM troubleshooting section, chances are very good MAZDA knows what's causing your problem. http://foxed.ca/foxed/index.php?page=rx7manual ** I may be thinking of Haynes... it's been a while since I've had to hunt through the manuals because my car kept stalling.. either way you should be able to find some insightful info. 2: Post good quality pictures of the engine bay from various angle and we'll see if anyone can spot anything obvious that a newb might not know about. personally, I still think your problem is related to the AFM or a vac leak but then, I'm not there... you may want to pull your injectors and send them off to KG parts for cleaning... it could be that your flooding but, I haven't seen any mention of trouble getting it started, just trouble keeping it running. Another thought... You may want to make yourself a test light and see if you're getting any trouble codes from the ECU. That could certainly help you narrow down any problems. http://www.teamfc3s.org/info/article...odes/main.html *Also, I notice you have put on your new coolant cap assembly. Does it have a pressure cap with a tube going to the overflow reservoir? I believe '88 models had the pressure cap on the filler neck there.
1988 GXL Last edited by RoughRex; 02-28-2009 at 05:55 PM. |
