Old 02-17-2009, 11:08 PM   #1
Brent
Sua Sponte
Brent's Avatar
So you just installed your 1600cc aftermarket injectors, correct? I'm guessing you did not drill and tap a spot in the rail for the stock fuel temp sensor? If this is the case, it's not too big of a deal. You just need to change all of the the fuel temp correction settings in the datalogit to 1.00.
and yes... "fuel" is the fuel temp sensor. Hope this helps.
