Sounds like the o-ring to me.
http://www.mazdatrix.com/faq/oring.htm What you are trying to prevent is having the gasket and O-ring squeezing out of place and blowing the oil (under pressure) into the front cover instead of through the engine. SYMPTOMS of this problem are lower oil pressure at all times, but especially when the engine is hot. A slight "squeeze-out" can give 10-20 lbs at idle, 40-55 at 3500rpm, and drop to 35lbs at 5000rpm. A large "squeeze-out" can give almost zero at idle, and maybe 35-40lbs above 2000rpm. |
