Old 02-12-2009, 09:51 AM   #2
RotaryProphet
Originally Posted by bigtony08 View Post
Hey guys im having a problem with my front right calaper sticking after you drive around for about 15 min. i have changed the brake lines, blead the brakes, and changed the hard ware and the problem still prosists. if anyone can help please post. Btw its on a 91 s5 with 4piston claipers with solid suspension
Strangely enough, I had something pretty much exactly happen on an S4. In my case, there was corrosion on the piston causing it to stick out once the brake was released.
I also had a problem where all the brakes would do that, and after changing the master cylinder and all the calipers, I finally replaced the brake booster, and it's been fine ever since. *shrug*
