Old 02-08-2009, 09:32 PM   #1
David Jerome
David Jerome's Avatar
You do NOT have to remove the ABS heat shield. Remove the intakes, secondary turbo inlet pipe, and the ypipe and you can see everything easily. If you were to still have clearance issues you can undo the motor mount bolts and lift the engine up with a hoist and push it towards the drivers side(about another 1/2 inch clearance.). There are 4 14mm headed nuts holding the down pipe on.
David Jerome
