Alright guys I'm 75% there on getting these Catch Tank kits done. The tanks are all mostly welded up, I just need to do the following.
1: Weld in passenger breather inlet line on the tanks. 2. Weld in customer specified upper mounting tab. 3: Drill & Tap Bungs 4. Make the passenger side breather lines (mounting flange, formed line, LIM support tab, braze it all together) 5. Polish or sand blast tanks 6. Ceramic clear coat tanks & paint breather lines. 7. Install Sight line fittings, drain valve, sight line tubes. 8. Package and ship to you guys. I need to know from each person other than RotaryWhat? and AHarada on what type of upper mounting tab you want. See picture below, you have the choice of the following, 1) power steering tab mount (requires you to drill and tap the tab on the power steering tank frame), 2) the original vacuum chamber tank mount (requires the rats nest frame work to be in place) |
Looking good
