| 2nd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
shookmotorsports.com
Help fund my addiction!
All prices are best offer and do not include 3% for pay pal.
Haltech E6X $600 shipped comes with GM water temp and clip GM air temp and clip GM tps, with clip (on harness) and bracket for the FC throttle body FD boost sensor with pig tail (2 bar) 2 Marren 550cc injectors no clips Wiring harness that should be replaced if you want the ECU in the stock location the Bad The AUX IN does not work and if you need the AUX IN to work the ECU will need to go to Haltech. If you can live with out the AUX IN the ECU functions just as a E6X should. ![]() ![]() Blue Greddy turbo timer with official mad tyt3 JDM yo! instruction manual $60 shipped ![]() ![]() ![]() Original Profec-B with blue case $270 shipped ![]() Izuzu NPR shorty $100 shipped ![]() ![]() Solid diff mount $40 shipped ![]() Front 5-lug hubs, they will need new bearings $50 shipped ![]() Turbo water pump housing, Has 3/8npt thread for the water temp sensor and the water return for the turbo is plugged $40 shipped ![]() Brand new never used S5 turbo tranny cross member $75 shipped ![]() S4 water pump w/ ~1000 miles $50 shipped I'll post a picture in a little bit. Last edited by moremazda; 01-19-2009 at 03:03 PM. |
Stuff still here, help, need a fix.
All prices are best offer.
