Old 01-14-2009, 06:27 PM   #1
sen2two
KTEC
sen2two's Avatar
im going to add that this is my first ever attempt of trying to make motor mounts.
i bolted the tranny to the motor (S5 NA trans) and put them in together and mounted the tranny using stock tranny mounting positions. i then propped the motor up using a floor jack getting it to the right height and location using a level to make sure its even.
the FD front cover is on there in the picture because i was planning on using it. for the main reason of using the FD crank trigger mounted on the front cover. but im since thinking of using the S4 NA front cover i have on there now and using the FC crank angle sensor. alls you need to do is swap the renesis timing gear for a 12a/13b one and thats it.
i'll be using an FC water pump and housing either way. mainly because the FD one is very ugly and bulky. plus the FC one is lighter. i'll be updating more when i get to it. there much much fabrication to come. most of it will be my first time, proving it dosnt take a pro and a bunch of money.
i'll be hoping for 220-230 WHP when all is complete. in NA form with MPG near 18-20 city driving. and more reliability than any other rotary with equal power. and far more street drivability. this will be a TRUE daily driver with A/C and all!!!
