|  12-29-2008, 09:02 PM | #1 |
| The Newbie Join Date: Mar 2008 Location: Tucson, Az
				Rep Power: 0  |
				power steering issue?
			Power steering starting making a little noise and sometimes doesn't work right away when starting the car. problems started after I changed the short hose between the pump and the fill tank. fluid acts like it needs to be bled (kinda bubbly and tries to overflow when turning wheel. I have now installed a different pump with the exact same issues as my previous pump. I have also tried jacking the front tires off the ground and with car running turned wheels several times with no effect. Any ideas?
				__________________   |
|  12-29-2008, 09:35 PM | #2 |
| Sua Sponte Join Date: Feb 2008 Location: Killeen, TX
				Rep Power: 18  |
			That's easy... pull all that stuff out and loop the lines.  You don't need it   Have you verified the pump is working or did you just switch one out with another one?
				__________________ Road Atlanta August 2011 NASA TT 1:33 http://www.youtube.com/watch?v=IFY00PAK_Ps Traqmate's video of my car from the 2011 UTCC at VIR http://www.youtube.com/watch?v=2Zcn6...layer_embedded Video of Yellow LS1 FD at NASA TT at VIR http://www.youtube.com/watch?v=e6k0lJkcwrM |
|  12-30-2008, 04:07 PM | #3 |
| My minds tellin' me no... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 22  |
			You need to bleed the pump by turning lock to lock slowly several times.  Sometimes it doesn't clear up for a while.  It took forever to bleed the 626's system after changing everything but the rack. Either keep at it, or return the pump and go manual. Chicks dig Popeye forearms
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
|  12-31-2008, 04:50 AM | #4 |
| Clean S4 Nutswinger Join Date: Mar 2008 Location: Sterling Heights, MI
				Rep Power: 18  |  . It's a piece of cake in the FC, can't be much worse in the FD.
				__________________ -Ted -1986 Mazda RX7 Sport [DD/beater]: engine finally let go at 205k. parts car status. -1986 Mazda RX7 base [resto-mod project]: S5 n/a swap in progress.   |
|  12-31-2008, 09:34 PM | #5 |
| Rotary Fan in Training Join Date: Mar 2008
				Rep Power: 18  | |
|  01-08-2009, 06:31 PM | #6 |
| Rotary Fan in Training Join Date: Feb 2008 Location: Bay Area CA
				Rep Power: 18  | |
|  01-14-2009, 08:53 AM | #7 |
| The Judge Join Date: Feb 2008
				Rep Power: 18  |
			Obvious that it is caused by air in the lines because that is what you did to it and two pumps acting the same.
|  01-15-2009, 09:29 AM | #8 |
| REVIT Join Date: Sep 2008 Location: Palm Bay, FL
				Rep Power: 18  |
				Power Steering
			Sounds like the system needs to be bled.
|  01-15-2009, 08:13 PM | #9 |
				Rep Power: 0  |
			After talking to a few local people, it seems as if it may be time for a new rack. possibly pulling in air. I've tried the bleeding methods offered of turning wheels lock to lock, and jacking in the air with motor off and turning lock to lock. Could the rack really be the issue?
|  01-21-2009, 07:10 PM | #10 | |
				Rep Power: 18  | Quote:
 Have you found any leaks? Check the hose you replaced. I replaced all my hoses, and the hoses to the plastic tank required extra care in clamping. The problem was that the replacement hose (3/8" to the pump and 1/2" inlet IIRC) were not exact matches for the OEM hose. I placed an extra clamp on each of these hoses, right next the the bead on the end of the pipe. That fixed it. One way to check for a leak is to feel the bottom of the P/S fluid tank. If either of those hoses are leaking, the bottom of the tank will be wet. P/S leaks look suspiciously like oil leaks, so you need to take some time to find out where it leaks. Yes, my P/S used to leak. | |
|  01-24-2009, 12:09 PM | #11 |
				Rep Power: 0  |
			Turns out the issue was definately the rack, Put the new remanufactured one in yesterday with new return hoses and everything appears to back to normal.  Thanks for everyones input.
