| Old School Rotary (Pre-1979) Pre-1979 Discussion including performance modifications and technical support sections |
Premium Vendor
Is there a way you can post up some photos????
plus I will see if I have a wiring diagram on hand.. Dan
82 SuperCharged rx-7 {my toy not the daily driver anymore now under restoration} 88 B2200 rotary powered with a 7inch Camden SuperCharger !RIP! Jan/4/2007 2001 626 5-speed 80k on the clock all stock {Truck replacement} 2005 MAZDA6 V6 WAGON now that is a pimping ride all stock for the moment.. Paid off WWW.AtkinsRotary.com |
Talk - Action = Nothing
First things first is to see if you have power on the positive side of the coils when the key is on. Also check for voltage when the key is in the start position. This is overlooked quite a bit by people modifying the ignition wiring and end up find a 12 volt source but it cuts off when the key goes to start.
The amount of voltage you have will depend if the dizzy is still a points dizzy or if it has been swapped out for an electronic version. If you have a points dizzy then you should see a pair of white ceramic rectangular bars. They will have threaded studs on each end. 12 volts goes in one end and the other end goes to the coils. This is to cut the voltage down in order to not burn up the points. Once you know you have voltage at the coils and have determined the style of distributor let us know. Also, you should be able to find a wiring diagram at vintagerotaries. Here is a link: http://www.vintagerotaries.org/index.php?showtopic=38 -billy |
