Yea check the screws on your brake rotors. I had one that came loose and it caused some strange clunking noises. I was suprised since I would have thought the lug nuts would have held it tight.
#2 | |
![]() I've heard stories from people that didn't torque their lug nuts and suffered the consequences. IMO it is a simple thing to remedy and not a bad habit to check the torque on them every so often. |
Frizen, I thought the same thing. Torque the wheels and the should be held tight. But I have the screws in ther and it started to back out and the rotor would make that noise like it was loose. Checked and re-checked the torque on the lug nuts. Only went away when i tighted up those screws. Noise went away and well that was all I did.
#4 | |
Reliable Source
Rep Power: 17 ![]() |
Yea, had to use that to get mine out, put anti-seize to try to keep them from doing that again, but with all the heat that goes throught there it will be a matter of time before you need that impact screwdriver to back tham out.
I used allen head screws so I wall have more leverage when I do mine again.
