My cheap Radiator that I had to modify the shroud to fit. Had to use bolts and nuts to mount it on the bottom and had to open up the holes on the shroud top sine it all was not lining up perfect.
Then I had to notch the shroud since the upper tube was at a different angle over the stock location (seen in the next group of pics). If you buy one of these keep in mind that its not a direct drop in nor does it have a drain or a line for the AST. If I would had known about this up front I would have spent more for the right one. But again $150 for this was not too bad even with the mods I had to do.
I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit) Last edited by fire85gslse; 11-23-2008 at 07:48 PM. |
more radiator pics.
Had to remove the name on it
I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit) Last edited by fire85gslse; 07-25-2010 at 07:30 PM. |
Motor sitting waiting for more work and harness to be complete.
Here is my motor sitting there now with the turbos back on.
I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit) Last edited by fire85gslse; 11-23-2008 at 07:59 PM. |
See you decided to pull the motor. Makes the work you are doing a lot easier. David is the turbo porting master. Work looks great.
Dan |
yep pulled it the next day after talking with you. Will go back in complete and ready.
I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit) |
