Old 11-20-2008, 01:20 AM   #1
Jeff20B
Jeff20B's Avatar
Wulff, I swapped from a 5" SC to a 7" today and I seem to have a stalling problem under braking now. It was very slight before with the 5" but is quite pronounced with the 7". I lowered the fuel pressure from 5 to 4.5 then to 4 and still the same.
It behaves like it's getting too much fuel because it bogs and stalls. To get it started back up I have to floor it as in a typical deflooding proceedure. Then it blows a bit of smoke which is also typical of having been flooded (washes all the oil off the internals).
The engine has lots more power and accelerates better than before but as soon as I slow down or make a panic stop, it dies/floods. Corners are less of a problem since lowering fuel pressure. Only stops cause problems now.
