#1 | |
Custom User Title
No, the FD uses a rear-mount setup. The FC uses a center-mount setup. That's why you need a first-gen style front cover in either case.
Edit: drewski86 is right about needing the GSL-SE oil pan. Forgot about that.
Since you are in Japan, (if you can speak japanese) call R-Magic. They just recently swapped the guts of a series 6 FD into a yellow SA22C.
If you need a name and number, PM me. |
