| Tires,Wheels,Suspension,Brakes Info about Tires, Wheels, Suspensions, Brakes, etc. |
Bah!
Not much in terms of tire selection, but the wider rim allows less sidewall flex, which is good for response. Pick up a set of 245/45/16 race tires and you should be quite competitive. 16's are also lighter as well.
If you have a 1 piece steel wheel, you can get them widened as well. There was a thread on the other forum about it, I'll try to dig it up later.
Johnson TA FC in the works! Last edited by MaczPayne; 11-05-2008 at 07:42 PM. |
#2 | |
Depends on what you like, but keep in mind that wider and or low profile tires lose their grip more suddenly. |
