#16 | |
Quicker spoolup is my main goal. I'm using an old Profec-B with the solenoid pressure sourced from the UIM. The "OUT" side of the EBC solenoid goes to the top of the WG, and the side of the WG is being sourced near the Compressor before the intercooler. Previously, I had the side of the WG pressure source coming from the UIM and I would get boost creep consistently. Have not seen any creep since sourcing from the compressor. Thanks - Kevin |
#17 |
I spoke to another owner of this kit and he is claiming actually slightly worse response in 3rd and 4th gear but marginally better response in 1st and 2nd? His car made around the same power at the same boost level, within about 10rwhp.
I havent seen many if any other dyno graphs or reports about this turbo. At this point I am lost on what is causing the slow response. Hopefully adjusting the Profec B will help dramatically. We will see I guess. Kevin, I know the wastegate spring is 13lbs, when you had it running directly off the spring bypassing the Profec was response really any better or have you tried this since have it tuned?
David Jerome Broker for Speed For Sale LLC (David@SpeedForSale.com) (Pre-owned RX7/sports car sales & new parts sales/installs/tuning) ![]() PM me about low priced, high quality port work
#18 | |
have you checked all your intercooler piping for leaks? intake gaskets? :edit: just read the above post copied from the other forum. the sp has a different hotside, but is getting better response than the standard 500r according to sean. so you should be hitting 15psi under 4k no problem.
![]() '93 SSM Touring-S475... ![]() '87 Tii-LS1/T56 Last edited by dregg100; 10-27-2008 at 11:45 PM. |
#19 |
It is hard to see in the graph that Kevin posted but the boost actually only fluctuates less than 1psi between 5100-7500 rpms. Only flucuated about .5psi from 5500-7500rpms.
#20 | |
Just to be clear, here's how I have it setup currently: - a line from Compressor to the side of the WG - a line from the (OUT) port on the solenoid to the top of the WG - a line from the UIM to the (IN) port on the solenoid - a line from the UIM to the Profec-B control box inside the car New UIM to LIM and TB Gaskets. No boost leaks that I can find between compressor and TB. Last edited by TurboSquirrel; 10-28-2008 at 12:19 AM. |
#21 |
have you tried changing the dip switches to the "other" settings that greddy says to do if you are having problems? its on there website.
![]() '93 SSM Touring-S475... ![]() '87 Tii-LS1/T56 |
#22 |
Thanks for everyone's suggestions so far!
After doing some logging this morning, here are my results after adjusting the GAIN setting on the EBC. Also, David suggested seeing how it did running off the WG only and I have included that result as well. There are three charts attached. The vertical line is the point where my expected max boost was obtained. Each run is in 3rd Gear from around 3000rpm (1) Chart_WGonly.JPG: EBC off (.9 BAR Spring) (2) Chart_EBC_HighGain.JPG: EBC on, and the GAIN setting high (overboosted) (3) Chart_EBC_Current.JPG: EBC on, and GAIN adjusted to desired boost After adjusting the GAIN settings, the best spoolup achieved was around 5300rpm. Running on the WG only did not appear to improve spoolup. |
#23 |
Wow, that is pretty poor response from an 0.84 A/R housing. I would expect 15 psi closer to 4k RPM.
Your setup seems correct to me. Someone already mentioned it, but check to make sure you have the correct settings on your dip switches. I would also expect better response off the wastegate alone, meaning that your EBC setup might not be a factor. Are you sure that you don't have any exhaust leaks on either side of the manifold? I had a friend with a similar situation and once he fixed his exhaust leak he was spooling 500+ RPM earlier than before. It was tricky too because you couldn't hear it at idle or cruise. It was really only leaking under boost and he had an open wastegate so there was no way to verify the leak until it started leaving carbon deposits under the manifold.
'93 RX-7 (GT3574 track toy) '74 Triumph TR6 (weekend cruiser)
#24 |
Im pretty sure Kevin doesnt have any leaks between the engine/manifold, wastegate/manifold, or turbo/manifold.
His response in 3rd gear is actually better than the only other person who has given me info about this kit. Its not impossible that there is a leak but everything on this car is brand new.
#25 |
Did you guys make sure the flanges on the manifold were flat?
Jack |
#26 |
600rwhp club member.
a-spec
I just dont think it could be the A-spec mani as thats the same mani I run but on a larger turbo (4094). I was seeing full boost around 4750 on my past setup (BDC streetport/ 3 inch exhaust).
#27 |
I dont think it is the manifold either. It appears it was my fault
![]() Kevin or myself will update this thread in a few days when I get a chance to work on his car. I have a feeling the spoolup will be much better. ![]() I wont leave you guys hanging, we had some fitment issues with the wastegate hitting the subframe with the kit. So I had to remove the wastegate from the manifold to drop the engine back in the car(we removed the engine to reseal the oil pan). I dont remember installing the valve seat that comes with the Tial BOV. We had to put on and take the wastegate off several times and it appears I never installed the valve seat that helps seal up the wastegate/manifold v-band connection. I will reinstall it in a couple days(hopefully have time) and we will report back. Kevin got his hands on about 5 other 500r dyno charts and they were all seeing 14-16lbs at about 43-4400 which is about 1k rpms sooner than Kevin.
#28 |
Hmmm...exhaust leak....
#29 |
That would explain a few things. Oh, by the way David, my turbo is a 68mm turbine vs. turbosquirrels 74mm turbine. An A to B comparison may occur some later next year once I get my car back on the road.
#30 |
Alright, problem is all sorted out now!
![]() I've attached PFC Charts showing 3rd and 4th Gear runs from around 3K RPM. Much better response than before with out the valve seat installed. Happy Days! |
| Tags |
| 500r, 500rsp, a-spec |
