wow thats awesome! i'm actually planning on buying the same kit, but their "500r-sp" kit instead.
#2 | |
- Kevin |
#3 | ||
The Judge
The boost curve is sloppy like your EBC is not functioning too well or not properly hooked up. It spikes and then drops off erraticaly.
Mine did that when I first hooked it up. Then I tried hooking my EBC differently than the manual showed. If you use the turbo outlet as your boost source for both the WG and EBC, then it senses a higher base pressure than the controlled pressure source. This is caused by the pressure drop in the IC. I take my pressure source from my Greddy TB elbow and that "Ts" into the WG side and WG solenoid input. The IC also acts like a filter to smooth out fluctuations. This made a great improvement in my boost control. You might also need to experiment with the GAIN to obtain the quickest spoolup that does not either cause spiking or boost start to increase. You max HP was produced at 15 psi boost. Thus if it stayed at 16psi, you would have made maybe another 15 HP. "Ray said I was making about 15HP / pound of boost." Last edited by cewrx7r1; 10-27-2008 at 10:27 PM. |
#5 | |
Quicker spoolup is my main goal. I'm using an old Profec-B with the solenoid pressure sourced from the UIM. The "OUT" side of the EBC solenoid goes to the top of the WG, and the side of the WG is being sourced near the Compressor before the intercooler. Previously, I had the side of the WG pressure source coming from the UIM and I would get boost creep consistently. Have not seen any creep since sourcing from the compressor. Thanks - Kevin |
#6 | |
have you checked all your intercooler piping for leaks? intake gaskets? :edit: just read the above post copied from the other forum. the sp has a different hotside, but is getting better response than the standard 500r according to sean. so you should be hitting 15psi under 4k no problem.
![]() '93 SSM Touring-S475... ![]() '87 Tii-LS1/T56 Last edited by dregg100; 10-27-2008 at 11:45 PM. |
I spoke to another owner of this kit and he is claiming actually slightly worse response in 3rd and 4th gear but marginally better response in 1st and 2nd? His car made around the same power at the same boost level, within about 10rwhp.
I havent seen many if any other dyno graphs or reports about this turbo. At this point I am lost on what is causing the slow response. Hopefully adjusting the Profec B will help dramatically. We will see I guess. Kevin, I know the wastegate spring is 13lbs, when you had it running directly off the spring bypassing the Profec was response really any better or have you tried this since have it tuned?
David Jerome Broker for Speed For Sale LLC (David@SpeedForSale.com) (Pre-owned RX7/sports car sales & new parts sales/installs/tuning) ![]() PM me about low priced, high quality port work
It is hard to see in the graph that Kevin posted but the boost actually only fluctuates less than 1psi between 5100-7500 rpms. Only flucuated about .5psi from 5500-7500rpms.
#9 | |
Just to be clear, here's how I have it setup currently: - a line from Compressor to the side of the WG - a line from the (OUT) port on the solenoid to the top of the WG - a line from the UIM to the (IN) port on the solenoid - a line from the UIM to the Profec-B control box inside the car New UIM to LIM and TB Gaskets. No boost leaks that I can find between compressor and TB. Last edited by TurboSquirrel; 10-28-2008 at 12:19 AM. |
| Tags |
| 500r, 500rsp, a-spec |
