New plan - RTek 1.5 for the S5. No more LIMP mode. I personally feel this is the way it should be. You can ditch the stupid problematic EMOP and either run premix, or swap to an S4 TB and Mechanical MOP.
Not to mention, this car has full 3" exhaust, so the RTek will help with adding a little security w/ the built in FCD and better timing adjustments over 9psi (which with this exhaust, the car should support 10psi all day). Should net a decent HP gain for not a lot of doe and it'll be seemingly factory without the factory headaches. |
