			 Non Member
				Rep Power: 18 ![]()  |
				GSL-SE 6P 13B Finding TDC?
			How would a person go about finding TDC on a SE 6P 13B, when the front pulley is installed wrong?
	I thought I saw it somewhere that the flat spot on the backside of the flywheel will be visible thru the inspection cover on the intake side of the engine. But, this brings up a new issue. The RB holley intake sits too close to the top bolt on this cover to get a socket on it. ![]() I certainly don't want to go thru the major hassle of dropping the header, to watch for an apex seal to go by the front exhaust port. So, is there another way to locate TDC, without tearing into the front of the engine, or dropping the trans, to see where the keyway(s) are pointed? That would be even more work than dropping the header.  |
			The fist time I faced a finding TDC issue, I grabbed a thick soft wire and pulled the L2 spark plug. You slowly rotate the engine by hand while 'feeling' with the wire until an apex seal touches it. You've just found BDC on the rear rotor and TDC on the front rotor. Back off a few degrees and install the pulley with the marks near the pin; it will be quite close.
	Almost no 'work' involved using my method. Enjoy.  |
		#3 | |||
				Rep Power: 21 ![]()  |
			there is another similar method that I found while reading the net:
			http://www.teamfc3s.org/info/articles/demystifying.html Quote:
			 Non Member
			Thanks! I never thought of using R2 spark plug holes to reference an apex seal, but it should work much the same as using R1 exhaust port. May not be 100% TDC, but dern sure close enough to know which way the pulley has to go.
	Damn, why didn't that thought come to mind?  |
			 Guest
					Posts: n/a
			how can the pulley not be on tdc if there is a key way?
	of did the GSL-SE 13b's have a removable timing crank pulley?  |
			 Non Member
			All 1st gen and earlier rotaries have a bolt on pulley with the timing marks on it. This pulley will fit the front hub any of 4 ways, as the bolt pattern is totally square, like a wheel & hub. The upside to these engines, they all have 3mm apex seals, or wider if you go old enough.
			 Guest
					Posts: n/a
			the FB 13B engines have 3mm apex seals?
	never heard of that.  |
			 Non Member
			Yepperz, GSL-SE 13B has 3mm apex seals. The rotors are heavy as hell, though..... (~11.5 lbs)
		#9 | |
			 Non Member
 It's amazing how much better it runs with those wires swapped, and the dizzy dropped in at factory spec.......  |
		#10 | |
			congrats, glad it's fixed!
		#11 |
			 Non Member
			I'm glad too. The car was FREE.........
		#12 | |
			damn, that's the best deal ever.
		#13 |
			 This Space for Rent
				Rep Power: 0 ![]()  |
			The only way I could get my car to work was installing the distributor 180 out. I wish there was the internet back then.
	Quote:I spent a lot of money on booze, birds and fast cars. The rest I just squandered. - George Best Quote:Beer is living proof that God loves us and wants us to be happy - Benjamin Franklin Rotary History: 1982 RX7 GS (12A), 1985 RX7 GSL-SE (13B), 2004 RX8 Sport (Renesis) - Continuous Rotary Owner since 1985 Racing History: SCCA Solo II 1979-1986, Skip Barber Competition School 1983, SCCA Club Racing 1987-1993  |
		#14 | |
			The internet is the best invention known to man.  Distances are no longer a factor when it comes to info.  I love it.
